Ran at the track today- 5/29
Old May 27, 2002 | 11:13 PM
formul8!!'s Avatar
Car: 2004 GTO
This was at Great Lakes Dragaway in Union Grove,WI (just north of Kenosha) . The temp was between 75-80, low humidity, light winds.
Best 60ft: 1.91 (BFG ZR radial)
Best E/T: 13.71
Best MPH: 98.79
I think with a cooler day, another 1/10 or two faster would have been there.
I am pretty happy with my times!! I haven't even intalled the headers yet. Hopefully, with the headers and some Nitto's, hope to see a 13.40 with STOCK heads and cam.
:rockon:
Old May 28, 2002 | 12:41 PM
tpi_roc's Avatar
not bad
You can always trim some fat to lower ET's
Theres plenty of weight to be found in thirdgens that doesn't need to be there.
Old May 28, 2002 | 01:54 PM
formul8!!'s Avatar
Car: 2004 GTO
I ran with the jack & spare out, but had a board (not a box) with two 12" subs and a 5lb amp. The subs and board weigh less than 50lbs, so it's a little ballast for the rear end.
I am looking into a VFN fiberglass '87-92 Formula hood and a fiberglass rear replacement spoiler to save more weight. That's at least 75-100lbs right there!!
Old May 28, 2002 | 03:54 PM
JucinGTA's Avatar
Sweet!! Hey if you need a Fiber Hood let me know, I deal with Glazteck in Naperville.:lala:
Old May 28, 2002 | 04:22 PM
johndo1707's Avatar
today is the 28th, lol
Old May 28, 2002 | 04:25 PM
tpi_roc's Avatar
He's running so fast he warped a day out.
Old May 28, 2002 | 05:41 PM
johndo1707's Avatar
yeah, i guess so.....fastest thirdgen alive!
Old May 28, 2002 | 05:58 PM
formul8!!'s Avatar
Car: 2004 GTO
Old May 28, 2002 | 06:24 PM
johndo1707's Avatar
:hail: :hail: :lala: :hail: :hail:
Old May 28, 2002 | 07:28 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Old May 29, 2002 | 10:24 AM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
13.7 with a stock cam and heads is awesome!!!!!!!!!
Hodge
Old May 29, 2002 | 10:57 AM
formul8!!'s Avatar
Car: 2004 GTO
I'm shooting for 13.40's with stock heads and cam.
Things left to do before touching heads and cam:
-1.6 roller rockers
-Install SLP 1 3/4 headers
-Frame connectors
-Accel 300+ ingnition
-Chip
-Nitto's
-'Glass hood and spoiler
-A NICE COLD DAY!!
Old May 29, 2002 | 11:11 AM
Guido's Avatar
Car: 2000 Trans Am
Good times Double D!! Get some more seat time in it and you will get it even faster.
I remember picking up over .5 in my car a few years ago just by learning how to drive it better. Launch better. shift at the right time. etc.
Again, great times. Keep at it!
Old May 29, 2002 | 11:22 AM
formul8!!'s Avatar
Car: 2004 GTO
Can I go 12.99 or better N/A and stock, untouched L98 heads and cam?
Stay tuned!!
Old May 29, 2002 | 11:24 AM
tpi_roc's Avatar
Sure you can
in the 8th
Old May 29, 2002 | 12:32 PM
johndo1707's Avatar
hahahaha....the 8th he says. i bet its possible
Old May 29, 2002 | 01:19 PM
formul8!!'s Avatar
Car: 2004 GTO
Anything is possible.....
Has anyone run this on a STOCK L98 bottom end, untouched heads and stock cam?
BTW, my 8.73@78.73 ain't too shabby! :lala:
Old May 29, 2002 | 01:37 PM
Guido's Avatar
Car: 2000 Trans Am
What brand of converter do you have in there DD? If you really want to shoot for the 12's NA Id think about a Vigilante. Not sure what you have now... maybe it is already.
Old May 29, 2002 | 03:35 PM
88ROC1LE's Avatar
that's not a bad 1/8 mile time, I run the 1/8 all the time and my best run is a 9.12 at 80 m.p.h. that was with a 2.2 60' time and on my kelly chargers seems like you should be faster than me through the 1/8 though all I have is whats in the sig
Old May 29, 2002 | 04:04 PM
formul8!!'s Avatar
Car: 2004 GTO
Curt,
I have a Continental 10" non-lockuo 2500 stall with a 16,000GVW B&M cooler.
It launches pretty hard now. Next time at the track, I will remove the STB and my two 12" subs in back. That should be another 60 or 70 lbs off the car. With the 'glass hood and spoiler, it should shave at least 100lbs off. I think 150-200lbs off should shave another tenth or two.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
loud91rs
Oct 5, 2015 10:05 PM
Jlanz55
Sep 29, 2015 08:55 AM
Lmancha96
Sep 25, 2015 08:11 PM
fasteddi
Sep 10, 2015 09:32 AM
