Nitrous HP cams? Any good?
Old May 28, 2002 | 11:32 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I need a better cam w/ more dur. than my ZZ4 cam. I was thinking about the Nitrous HP cams that Comp Cams makes. Is anyone here running them or have thought about using one. I plan on spraying 100 shot from my NX kit.
My goal is to have a 11 sec. car I can drive to work everyday. Do you think this will help.
PS- I got better valve springs that can handle .600 lift and 7500rpm. I also installed a set of 1.6RR.
Old May 28, 2002 | 12:24 PM
tpi_roc's Avatar
7,500 rpms?
You better be running solid lifters.
Old May 29, 2002 | 11:10 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I don't plan on taking it to 7500, I just wanted a spring that could handle over .550 lift.
Have had any experience with those cam?
Old May 29, 2002 | 11:14 AM
tpi_roc's Avatar
Not personally, but usually the nitrous cam is only different in the Intake/exhaust numbers have a wider spread
example:
224/230 505 510 Normal
224/234 505 520 NItrous...
This is because of the increased exhaust due to nitrous vs the same amount of air intake
For 100 shot you hardly need a "nitrous" specific cam. Just get a cam by numbers that suits your needs.
Old May 29, 2002 | 11:41 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Old May 29, 2002 | 11:07 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
i would say that the cam you want really depends on how much you are going to spray.
if you just use the nitrous as a little extra sometimes then get a cam that will suit your cars N/A needs.
if you plan on using the nitrous quite frequently (every time you race) then a nitrous cam will actually make 20-40 more hp even on a small shot(over a regular cam). BUT! it will make less hp when you aren't spraying, odds are 15-30 less hp than the regular cam. its like tpiroc said you have more exhaust and need to get it out.
Andrew
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
TreDeClaw
Aug 14, 2015 06:58 PM
