spark plug gap
Old May 28, 2002 | 01:37 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
spark plug gap
i have an 85' TPI car w/ an MSD 6AL and 8mm Taylor wires, the rest is stock.... what should my spark pluge gape be?
Old May 28, 2002 | 02:55 PM
tpi_roc's Avatar
You could probably run .050 with your upgraded ignition
Stock runs .035-.045 (hei)
Old May 28, 2002 | 10:53 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Put in Bosch Platinum +4 and forget it.
Old May 29, 2002 | 01:05 AM
tpi_roc's Avatar
Haha
Do NOT run +4's
Old May 29, 2002 | 08:42 AM
i was just going to run regular AC Delcos
Old May 29, 2002 | 09:27 AM
tpi_roc's Avatar
They work just fine
Also NGK's are a good yet cheap plug.
Unfortunatly I HAD to run accel shorties
Old May 29, 2002 | 01:31 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Roc what is your opinion on why +4's are not good plugs.
Old May 29, 2002 | 01:34 PM
tpi_roc's Avatar
The price mainly.
I've witnessed them cause knock at lower timing and compression than other single electrode plugs on the market, the last thing a thirdgen needs is more detonation
I refuse to run platnum anything in my car.
(Unless it was a stock 4 cylinder which I dont/wont own )
Old May 29, 2002 | 03:19 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
Originally posted by tpi_roc
The price mainly.
Same here...will not touch platnum plugs
Old May 29, 2002 | 03:53 PM
TransAm87's Avatar
hey
Just run AC Delcos, heard other dont do much unless on a HIGH PERFORMANCE motor
Old May 29, 2002 | 03:56 PM
tpi_roc's Avatar
quite the opposite
"Others" (being platnum) have no place in "high performance" engines, last thing you wanna do is melt off some platnum and get it stuck between a ring at 7k rpms.
Platnums belong in stock engines giving them a little bit longer life and maybe a tiny bit of umpf
Old May 29, 2002 | 09:46 PM
383 rocket bird's Avatar
I just built my Vortec headed 383 and all the plugs listed for these heads are platinums
Old May 29, 2002 | 10:50 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
TO EACH HIS OWN. THAT'S WHY THEY MAKUM MANY KINDS.
I HAVE +4'S IN MY VET WITH MUCHO HP
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 9, 2015 09:09 AM
Jlanz55
Sep 6, 2015 03:05 PM
