UPDATE-found out what ses light means, now i need some more help
Old May 29, 2002 | 11:44 PM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
well guys/gals, guess what! i found out what my service engine soon light kept coming on intermittently for. it popped up codes 33 and 36. both are basically the same thing, low voltage to the maf sensor itself, and low voltage to the maf burn-off wire (im guessing the wee lil wire in the middle that everyone is so scared to break?). well my first instinct (although maybe not the right one) was to check alternator voltage. i checked first on the silver lug with one wire on it (hey, gimmie a break, i work on humvees, i wasnt exactly sure how to check it!) there i got nada. then i checked the little red wire, there i got about 31 volts AC. is this too much? so my next probable cause is this. the last retard that had my car put SILICONE on all of the sensors! and it wasnt sensor safe! so i think now, even with the new maf, i may be getting a bad connection. what do you guys think? the reason i see for all the dern silicone, on that particular connector anyway, is because he broke the connector all to hell. so my proposed solution is as follows: find a new connector, butt-splice it into the wiring harness after checking the rest of the wiring harness (the cut ends.) for proper voltage, continuity, etc. so the help i need is as follows, i need to know what wires for the mafs to check and what their proper voltage should be, also i would like to hear any other probable solutions to fix this problem (it only happens every now and then, if you turn the car off and wiggle the harness underhood it will sometimes shut the light off, rarely though, and sometimes its enough to make the car stall.) i would greatly appreciate any help i can get. thanks!
1987 Pontiac Firebird Formula WS6
TPI 305 (Mustang eatin S.O.B.!)+
T5 5 speed tranny to handle all business transactions+
245/50ZR-16 Pirelli tires=lotsa fun
lots more mods to come...
"A Mustang a day keeps the junkyard away!"
Old May 30, 2002 | 12:44 AM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
if i were in your shoes i would not touch anything and go get a mass air flow sensor burn off relay (maf burnoff relay) its usually the culprit and its only like 8-10 bucks
if that doesn't fix it just take it back and say you got the wrong sensor and that the problem is fixed now
if that doesn't work then go to town but don't mess stuff up for a little relay
Andrew
Old Jun 1, 2002 | 06:56 PM
question...
where is the MAF burnoff relay located?
TPI 305, T5 manual, loads of fun!!!
"A Mustang a day keeps the junkyaard away!"
Old Jun 1, 2002 | 07:12 PM
Morley's Avatar
Driver side against the firewall, there's like 3 relays and the ESC there.
~M~
eightsixseven
Dec 16, 2024 01:50 PM
GTAman
Mar 15, 2019 11:40 AM
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
