Aftermarket fuel pump. What kind are you using?
Old May 30, 2002 | 01:21 AM
RODS92Z's Avatar
Wondering what kind of aftermarket in tank fuel pump everybody is running and at what psi does it run and how much fuel per hour. Also give your car specs. Thanks.
Old May 30, 2002 | 05:22 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Walbro hi-pressure 255LPH, $108. Direct replacement and highly recommended. I got it from http://www.autoperformanceengineering.com/
Mods are in my sig.
Old May 30, 2002 | 10:29 PM
RODS92Z's Avatar
Ok, Thanks for the advice. I'll check them out.
Old May 31, 2002 | 11:22 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
i'm running a Walbro 340 intake pump, er well i will be one my lazy *** gets around to putting it in
it'll give me enough fuel for high 10's
Old May 31, 2002 | 05:03 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Just so happens that I had to get a fuel pump for my GTA today.... damn thing took a crap on me yesterday. I knew something was messed up the last few weeks, but I was kind of chasing my tail until the pump totally failed.
I went with the Walbro 255 High Pressure pump and a Hot Wire kit.
FYI, the Walbro 340 is the 255 High Pressure pump. The 255 Ltr/hr pump comes in two versions and have different part numbers. There is also a 190 Walbro. Here is a breakdown of what kind of flow the different Walbros put out:
http://www.autoperformanceengineerin.../fuelpump.html
And here is the Hot Wire kit info:
http://www.racetronix.com/Racetronix...p_Harness.html
All of my turbo Buick friends swear by the Hot Wire kits so I figured I would toss that in with the new pump to ensure it gets lots and lots of power .
Old May 31, 2002 | 05:23 PM
RODS92Z's Avatar
Thanks guys I appreciate it. Yeah I've been chasing mine around too. It starts to quit pumping when its hot outside. Just keeps getting worse, right now I can hardly drive around town. Then when it does quit I have to get out and bang on the gas tank to have it kick back in. Getting to point where I cant stand it.
Well I purchased a Holley in tank fuel pump off ebay for $75. It pumps 270+ lph . Cant remember the exact # of liters.
Old Jun 1, 2002 | 12:38 AM
fly89gta's Avatar
Car: 2018 Camaro SS
and rightfully so..there is truth behind the pump having voltage drops..think of that hotwire kit as a $50 insurance plan
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
