Question about a CFI 2 TPI
Old May 30, 2002 | 03:39 PM
khellendros's Avatar
How hard is it to make a CFI into a TPI? Is it even possible? If so how hard... If not how can i make it have the same Hp/ FT*lbs?
Old Jun 1, 2002 | 01:34 AM
tpi_roc's Avatar
WHo cares, bottom line is it isn't worth the effort.
Old Jun 1, 2002 | 02:15 AM
Blackened's Avatar
Maybe he wants to do it for looks. That's the only thing TPI would be good for. LOL
Old Jun 1, 2002 | 11:04 PM
TPI_Roc
I didn't say you cared, nor did i say i wanted a response from someone who didn't care... more less i care, and if u dont, dont bother anwsering. Thanks
Old Jun 1, 2002 | 11:50 PM
tpi_roc's Avatar
Think of me at the end of your project
when you say to yourself "wtf was that waste of time for"
Peace
Old Jun 2, 2002 | 12:10 AM
So tell me... why do u bash that engine anways? It put out 175 hp and 250 ft/lbs of torque at 2800 rmp.... Personally i like the look of it better then the TPI on top of that.... What are your reasons for dislike.... i hear everyone talkin trash about them, then nobody wants to talk about what they dislike... and dont gimme that crap about induction
Old Jun 2, 2002 | 12:31 AM
383 rocket bird's Avatar
Blackened, where did you learn how to do that dash mod. That looks awesome. Is it on a web page somewhere? Thanks for any help
Old Jun 4, 2002 | 02:43 AM
nsimmons's Avatar
this is what you want
http://www.crossfire.webhop.net/cftest
swapping to a tpi is expensive alot of work and you gain little, simply modifying the stock intake manifold and you can achieve the same airflow as the tpi.
Old Jun 4, 2002 | 03:19 PM
SilentBob's Avatar
Car: it doesnt really drive right now
Engine: 383
A friend of mine is trying to make his 84 CFI Vette go fast. He built a 383 to go underneath it and...... Well the results were dissapointing. He switched to 454 truck injectors and ported the crap out of the intake and got some gain. Then a bolt fell into his motor and cut the project short.
Right now, he has his 383 back and is modifying the crap out of the intake to try and make it work. He is switching the way the fuel distribution works as CFI leans the back four cyl, due a GM kludge. He has cut the EGR passage out and is going to send his throttle bodies out to be ported. Apparently there a guy out there that is taking them to 54mm, but has to sleeve them as they run into the IAC(I think).
Also, the fuel system was totally lacking for the motor and so he redid that. The complaint I heard from him is that all the pieces were perfectly in tune with the others and so replacing one piece does no good, they all have to be done to be of any value.
Im sure I have missed alot in his ongoing CFI saga. If you want to get in contact with him, let me know and Ill pass along his e-mail address.
SB
Old Jun 4, 2002 | 06:37 PM
nsimmons's Avatar
your correct, then engine must be designed as a system, also you cant just throw 90# injectors on the engine, it wont run properly there must be stagger. The stock injectors are 60# and 66#, if you want to use 2 90's you have to plumb the tbis in parallel. Also the only person i know of who's sleeving the tbi's is dan plett on the crossfire forum. He's taken them to 2.125" and flow tests show just over 750cfm for the pair. Another member too has just sleeved his to 2.25" and is expecting 800cfm.
Most important, you have to change the ecm to a 7747 so you can tune it. The stock programming wont work on an agressive 383
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
