Gasket sealent
Old May 31, 2002 | 08:53 PM
86IrocMN's Avatar
Gasket sealent
Is it necessary to put sealent on the gaskets for the runners? If so which side both or just the intake manifold side? and also on the TB gasket should you have sealent on both 1 or neither sides?
Old May 31, 2002 | 10:33 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
its not really necessary to silicone the runner gaskets but if you want to its easier to silicone only one side for dissasembly later on if you intend on taking it apart. Just make sure like on everything else you use silicone on that you use the sensor safe stuff, regular silicone especially in air passage ways likes to kill O2 sensors
Old May 31, 2002 | 10:40 PM
Morley's Avatar
I wouldn't use silicone on them for sealant. If you want to seal them use Permatex Hi-Tack gasket sealant.
~M~
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
