What size injectors should I buy?? 24lb etc?
Car: 1986 Pro Street Iroc-Z
Engine: 383 Stroker
Hi guys
I am in the process of purchasing a new set of injectors. What size and type should I buy. I have nearly every bolt on imaginable. I have ordered a set of SLP runners and am porting the plenum and bottom intake. I have a ford 9 inch with 3.91 gears. 2500 stall with a new rebuilt to spec tranny. a brand new 350 with 2040 compucam and matching springs. stock heads for now though. Flowmaster exhaust and headers. MSD digital 6 and 150 shot of nitrous.
So any suggestions guys? Right now i am running 19 lbinjectors at 52 lbs of pressure.
thanks in advance.
Jamie James
thanks in advance.
Jamie James
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
I bought a set of Accel 24lb injectors and I yanked them out of the car and put the 19s back in. A lot of the PROM burning guys in here said that I'd be running real rich until I programmed a custom prom for the car. Right now I don't have any of the equipment to program proms so I put the old injectors in. I have other things that need to be done to the car first . . .
toronto formula
Nov 10, 2015 06:17 AM
Firechicken86
Aug 12, 2015 10:07 PM
knight72
Aug 10, 2015 09:32 PM
