Rich TPS.........?
Transmission: World Class T-5
Axle/Gears: BW 3.45
Rich TPS.........?
Can setting your TPS at the upper range, like around .60V, cause you to run rich?
Axle/Gears: BW 3.45
I set my TPS at about .59v...and immediately thereafter the car started running rich.
I'd get a black cloud at startup.
After awhile, I started getting a rough idle....which I'm still trying to fix.
I wonder if there was any connection?
I dont' mean to butt in but what would the reccomended setting for the tps be? My friend told me that he thought it should be arround 80mv but I can't remember. I have it set at 60 right now.
Only Way that would happen is if you are getting into PE earlier.
How do you know your Running Rich ?
Black cloud at startup Could easily be leaking injectors.
I think .54V at idle is the Recommended setting.
4.5V + at WOT.
4.5V + at WOT.
Axle/Gears: BW 3.45
The recommended setting is 0.54v + or- 0.075 volts.
Axle/Gears: BW 3.45
But I still havw the rough idle.
