350 TPI timing question
Old Jun 10, 2002 | 08:36 PM
Patton's Avatar
What should the timing be set at for a 88 350 tpi camaro automatic?
Old Jun 10, 2002 | 09:27 PM
Swapmaster's Avatar
The stock setting is 6 deg BTDC.
Old Jun 10, 2002 | 11:08 PM
gmanrs70's Avatar
If you look on the underside of the hood ther should be all the specs for your timing. It should read 6 deg btdc . You will also unplug your brown/black wire located on the passenger side firewall. If your sticker under your hood says 6 DR that would indicate in drive. good luck.
87 350 TPI
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
