Open vs. Close loop..explanation/help!!
Hey guys, I the scan tools and past tech ?;s i have noticed people mentioning closed and open loop etc...Can someone explain to me the difference between closed and open loop and so on?
thanks
Anything will help
Aj
thanks
Anything will help
Aj
In open loop the ecm takes/makes its calculations without consideration of the 02 sensor reading. Once the ecm switches to closed loop it will take (over time) averages of the 02 and try to balance it out to 14.7:1 (or stoich) Air / Fuel ratio. But Is still heavily biased to a table based fuel delivery calibration.
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
For effeciency and emissions reasons yes. However the O2 sensor isn't at all accurate at WOT, which is why the ECM switches back to open loop when you floor it.
83 Crossfire TA
Sep 8, 2015 12:06 PM
