balancing motor
Old Jun 12, 2002 | 09:05 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
balancing motor
ok i am building a 355 and everything i have has been balanced as a set.... i.e. rods all weigh the same but do i really need 2 balance the whole rotating assembly? please help in a TPI car so not gonna get too high of revs.....
Old Jun 12, 2002 | 09:56 AM
tpi_roc's Avatar
yes you REALLY need to balance the rotating assembly.
Old Jun 12, 2002 | 11:59 PM
poncho9789's Avatar
Balancing the whole rotating assy. includes weight matching the pistons, and rods. After the rods/pistons are weight matched the weight of the rings and berrings plus the weight of the pistons/rods and then that ammount of weight is put on the crank and the machinest grinds or welds material to the crank/balancer/and flywheel
It is really better to balance the whole assy. it normally doesn't cost too much when weighed to it's advantages. I paid $150 to have my assy. computer balanced.
Old Jun 13, 2002 | 08:30 AM
86IROCTHD's Avatar
Car: 88 Trans Am
thanks
thanks guys its 150 to get it done..... sending it off next week...... i want this motor bad lol......
italiano67
Dec 11, 2016 09:21 AM
hydrolic144
Sep 8, 2015 06:55 PM
gixxer92
Sep 1, 2015 04:32 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
