what kind of roller rockers is everyone running.
Old Jun 12, 2002 | 12:56 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Im thinking about gettin some roller rockers for my stock L98 heads. I would also like to go to a stiffer spring.
Im keeping the stock cam for now. Which rockers would work good, and which springs will work without any bind.
thanks for info.
Ps. Im thinking of going with trick flow heads later, and would like to use them on the trick flow heads. Keep in mind I will be converting to a stealth ram also, before the new heads.
Old Jun 12, 2002 | 01:41 PM
kevinc's Avatar
Car: 1982 Z28
GM Performance Parts 1.6:1 self aligning roller rockers that came in my LT4-HOT cam kit.
The kit came with springs which I'm running, don't know what machinework is needed to fit them onto stock iron L98 heads tho. They're good to 0.525" lift (exactly what the LT4-HOT cam does with 1.6:1 rockers).
Old Jun 12, 2002 | 01:52 PM
383 rocket bird's Avatar
I have the same setup as him.
Old Jun 12, 2002 | 09:08 PM
3gc's Avatar
3gc
Car: Z28
I have Harland Sharp roller rockers in my l98 buildup on vortec heads.
These won't fit under the stock valve covers, I got TD Performance tall valve covers. I think Comp Cams make rockers that'll fit under the stock valve covers.
Old Jun 12, 2002 | 10:01 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
The GMPP rockers / Crane Golds (same thing) will fit under the stock valve covers.
Old Jun 13, 2002 | 12:52 AM
Wolfpack's Avatar
Car: 86 Iroc
ooo what purty engine (drools)
Old Jun 13, 2002 | 07:15 AM
Garett92Z's Avatar
i am thinking of getting roller rockers next winter. My motor L98 was just fully rebuilt. How much of a power difference will I notice along with my setup (exhaust, intake, ported TPI, SLP 1 3/4 headers, MSD) ????? 10hp?
How hard to install?
Old Jun 13, 2002 | 10:10 AM
matt_at_ttu's Avatar
Comp Cams Pro Magnum
Old Jun 13, 2002 | 10:18 AM
Beefy89's Avatar
Same as above.....
Old Jun 13, 2002 | 10:25 AM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
Crane 1.5 Roller Rockers
Old Jun 13, 2002 | 10:35 AM
Brian'sIROC's Avatar
Comp Magnum here too. The self aligning type. They also fit the stock center bolt valve covers.
Old Jun 13, 2002 | 10:46 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Thats what I got.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
TexasMaro
Sep 15, 2015 06:50 PM
