Who's got a Hotcam in their daily driver?
Old Jun 12, 2002 | 11:19 AM
Beefy89's Avatar
Just wondering if anyone is running an LT4 Hot cam in their daily driven car....Drivability OK?
Old Jun 12, 2002 | 01:16 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Yup, been running it for about a year and a half now. You will have to reprogram your PROM for it to be driveable though. And you'll probably want to set your idle a little higher too, mines at 750 rpm.
Old Jun 12, 2002 | 01:39 PM
kevinc's Avatar
Car: 1982 Z28
Same here, built the engine in 1998 and put it on the road in 1999. Passes NJ treadmill emission test no problem, gets 28+ mpg on the highway, and ran 13.19sec@102mph back when I had the auto trans in.
My engine specs are in the page in my sig...I wouldn't run this cam (or any other big cam) in a stock engine with low compression or stock heads. Waste of $$.
To make it run efficiently you'll need to do some software tuning, but the process is covered in the DIY_PROM forum notes.
Old Jun 12, 2002 | 02:59 PM
tpi_roc's Avatar
I dont recall the hotcam specs, but I think mine are very compairable.
224/230@.050
512 lift
With 200cc intake runners...
Deffinatly streetable, assuming you've got very deep pockets
I've spent $30 on gas this week and its wednesday.
Old Jun 12, 2002 | 09:37 PM
kevinc's Avatar
Car: 1982 Z28
Wow, that's a lotta gas to burn. Do you have 1/4mi times on it?
I'm running the wimpy 163cc aluminum Vette heads and 3.42 gears, probably accounts for the better fuel mileage and isn't hurting me too bad in the hp/torque dept.
Old Jun 13, 2002 | 12:17 AM
tpi_roc's Avatar
Not yet
But if my 500 break in miles are in by friday I might go find out what she's got in her.
Unfortunatly im on an uphill tuning battle without my laptop
F.I. 57 Belair
Aug 23, 2021 01:09 AM
ramicio
Sep 28, 2015 01:18 PM
david068513
Sep 18, 2015 10:36 AM
rsrookie
Sep 5, 2015 07:08 PM
