MAF & MAP and K&N filter question
Old Jun 13, 2002 | 03:06 PM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
My g/f has this filter on her 383 TPI Trans AM, its an 91 so its got the MAP speed density basically and I have MAF, so my question is, the jegs catalog says won't work with MASS-Air flow?
So I can't use this filter heh? Any way around it?
Or is there another setup I should look into?
OR was this a stupid question?
Old Jun 13, 2002 | 03:35 PM
Chevero's Avatar
It is a physical fit situation. Your g/f has MAP with nothing but air tubing upstream from the throttle body. So, in her application, the upstream tubing is by-passed, and the subject K&N mounts right on the TB.
Your MAF setup has the actual MAF sensing component (it measures the air flow before it gets to the TB) upstream from the TB, and cannot be by-passed. Also, your tubing is round, and the subject K&N is made to mount on the oval TB. So if you did find room for the K&N upstream from the MAF sensor, you would need to make an oval adapter to use it. I think K&N makes a filter for your MAF applicaton, but it is not the same as your g/f's.
Old Jun 13, 2002 | 03:36 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Yea it will not work with Mass Air. You will need to switch to speed density in order to use that setup. The best way for you is to gut your air box and make a "ram air" system. There is a tech article on how to make in on the main page. I have gutted my air box but am to lazy to make a "ram air" setup. I am going to get to it eventually.
Old Jun 13, 2002 | 04:25 PM
tpi_roc's Avatar
On another note....
The cone filter is only going to feed your engine hot air.
Old Jun 14, 2002 | 02:23 AM
cort351w's Avatar
Is your GF by any chance using a cowl hood? I ask because when I tried that K&N on my TB, it rubbed the underside of the hood (stock powerbulge hood). Just curious.
specialized
Jun 18, 2022 09:26 AM
Logan Bryant
Aug 27, 2015 11:52 AM
Bert87
Aug 23, 2015 03:50 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
