Crane 2030 or 2040
Old Jun 15, 2002 | 01:06 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Crane 2030 or 2040
Yes I did search!
looking in the tech section the 2030 is barely bigger in duration and has more lift than the 85 GOOD cam. Only the 2030 is on 110 LSA. The 2040 is on 114 LSA much like the 85 cam with just a little more duration/lift.
Specs......
86 Peanut .350/.385 179/194 109 LSA
85 lLB9Cam .403/.415 202/206 114.5 LSA
Crane 2030 .423/.446 204/214 110 LSA
Crane 2040 .440/.454 210/216 114 LSA
Seems to me the 2030 is just barely better than the stock 85 cam, and the 2040 would be a upgrade. Either would be better than the peanut POS I have now!
BTW the 2030 is on back order. I ordered thru local speed shop. While checking specs on Summit, they list a 8-1-02 date, Crane says mid August. The 2040 is in stock and ready to ship. I do plan on changing the valvesprings/retainers/pushrods at the same time also.
My car......1986 TA 305 AT, 3.27 BW rear, 1991 GM erplacement tranny with 2200 stall corvette convertor. I normally cruise at 2000-2200 rpm on the highway. I also plan on port the base and plenum while topend is torn down. I do plan on cutting the walls out in the base per the tech article. I also have the Crane FPR to add also.
My guess is about a 45-50 hp increase on the top end. Current cam falls flat at 3700-3800 rpm.
THANKS for info/suggestions.
Old Jun 17, 2002 | 06:53 AM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I would go with the 2040 because it has a more duration and more lift. I also thought the pre86 cars were flat tappet cams. I'm not sure if the 2040 is a flat tappet cam or not.
Old Jun 17, 2002 | 07:57 AM
Mista's Avatar
Car: 1986 Trans Am
2030 and 2040 grind can both be had as old style hyd. flat tappet grinds.
BTW I just changed the order to Crane # 114132 cam. Should be 10 hp gain over the 85 cam, or 35-40hp from cam ALONE!
I hope for mid 14's after the cam swap and porting the plenum and lower base.
Old Jun 17, 2002 | 10:00 AM
tpi_roc's Avatar
Since when is the crane 2030 a 110 lsa
Old Jun 18, 2002 | 04:47 AM
Mista's Avatar
Car: 1986 Trans Am
http://www.cranecams.com/master/apps/chevy5.htm
Cam #3, Powermax 2030
Old Jun 18, 2002 | 09:32 AM
tpi_roc's Avatar
Ok not compucam
Old Jun 18, 2002 | 09:51 AM
Snowdog 91 Formula's Avatar
Flat Tappet PowerMax 2030
Yep! That is what is on my car.
I will tell you guys the 2030 is not disappointing at all! Definitely worth it! Another consideration is the 2031/2032 FT.
Hotrodboba400
Dec 10, 2019 07:07 PM
TexasMaro
Sep 15, 2015 06:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
camaro71633
Sep 1, 2015 10:24 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
