Should i buy a air foil????
Old Jun 15, 2002 | 08:38 PM
mikesstkiroc's Avatar
Has anyone bought a air foil for their TPI. Let me know what you thought about the air foil. Do you think its worth the $50.00 or should i save my money toward something else.
Old Jun 15, 2002 | 10:22 PM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
if you watch on Ebay, you can get the for $25-30
Old Jun 16, 2002 | 09:38 AM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
they dont give much of a power increase. i did this along with a few other free mods and gained practiclly nothing. however, if you never plan on going bigger than the stock TB, i would get it, as the design does smooth airflow. this mod falls into the "every little bit helps" catagory. if youre looking for a noticable power increase, do some exhaust work, the factory system is very restrictive
Old Jun 16, 2002 | 06:39 PM
the exaust is already done. cat back with flowmaster muffler. i am planning on getting another tb maybe a 54 or 58 mm. so you don't think its worth getting with the stock 48 on it.
Old Jun 16, 2002 | 06:48 PM
BOTTLEDZ28's Avatar
Transmission: A4
The airfoil showed a 1hp gain on an LT1. Its not worth $50. Check ebay and see if you can get one at half the price if it makes you happy to have it. Also, you say you plan on going to a 52 or 58MM TB. most aftermarket TB's already have one built into them. And a 58MM TB is usless unless you have a lot of horsepower.
Old Jun 16, 2002 | 07:23 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you're going to spend money on one, get eth SLP. It's the cheapest at $26 last time i checked, and will work just as well as any of the high dollar ones.
Old Jun 16, 2002 | 08:01 PM
camaro6spd's Avatar
or if you are luck..BOTH not just one of your cars comes already equiped so you don't have to bother....hell if the K&Ns and the Airfoil add nothing i still well be happy....i personaly don't belive in buying these things....maybe the K&Ns b/c they clean better....right?
Wylecoyote08
Nov 6, 2015 03:46 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Street Lethal
Aug 13, 2015 08:28 PM
mustangman65_79
Aug 11, 2015 03:17 PM
