need help on verifying engine size
i don't know where to post this question so i'm going to post it here. I'm looking at a 86 iroc-z, the vin number says that it's a 305, but he claims that the owner before him dropped in a 350, i know that there were only 50 5.7 camaros produced in 1986, so is there any way to prove that it's a 350? And it's definetly TPI. thanks a lot.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ermm.. there prolly won't be one there. I'm assuming this is Carburated ?
You can:
1) Pop a valve cover and check the casting # on the head.
2) Remove the wiper motor, and stick your head in there and look
at the casting number on the top of the motor behind the head.
The LG4 (305's) from that period usually said:
"GM 5.0 LG"
Followed by a casting #..
Basicly, the wiper motor is the only real obstacle form reading the casting #.. Depending on year, they may or may not be one on the side.
-- Joe
You can:
"GM 5.0 LG"
-- Joe
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
Originally posted by Scott 88 GTA
No, he said in his last sentence that it's a TPI. But yes, the casting number is the only way to verify it without pulling a head and measuring the bore.
Andrew
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
knight72
Aug 10, 2015 09:32 PM
