LT1 intake gasket
Old Jun 17, 2002 | 09:43 PM
ssbowtie1's Avatar
LT1 intake gasket
I'm rebuilding my 88 350 with WP heads and was wondering what intake gasket I need for the lt1 intake. Will an intake gasket for a regular tpi setup work or do I need an lt1 intake gasket? Thanks everyone for any help
Old Jun 18, 2002 | 05:41 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Regular intake gasket from a small block chevy. Preferable get an aftermarket Mr. Gasket that doesn't have EGR holes in it.
Old Jun 18, 2002 | 05:49 AM
ssbowtie1's Avatar
part number?
Does anyone know what part number I would need to get a gasket with no egr ports?. What do I have to do if I use a gasket with egr ports? Thanks
Old Jun 18, 2002 | 11:39 AM
tpi_roc's Avatar
Felpro 1205
Take extra care and steps in sealing such a large gasket due to sealing surfaces lost in a performance gasket.
With this particular gasket I've had best luck with a super thin ring around all water ports on the heads and intake, then another thin ring of sealant around the water jackets of both sides of the gasket.
Old Jun 18, 2002 | 11:39 PM
ssbowtie1's Avatar
Actually I just found out that my head are the pre 87 style heads. Can I still use the felpro 1205 gasket? How am I supposed to know the angle that the holes have to be in for the bolts? Thanks for any help
Old Jun 19, 2002 | 01:22 AM
tpi_roc's Avatar
Yes, still use the 1205
Old Jun 19, 2002 | 09:13 AM
ssbowtie1's Avatar
Ok last question I promise First off am I supposed to completely guess the angle of the intake? If the angles are the same as the corner holes, then I can work off of that or are they at a different angle? Finally, I know that I need to use allen head bolts to thread into the intake, but how long are they supposed to be? Thanks again you guys have been alot of help.
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
