Stealth Ram swap ?'s
Old Jun 19, 2002 | 12:14 AM
Fade07W's Avatar
Okay I just got done doing some reading on the stealth ram set up. The holley website makes it sounds like the kit comes with everything to go from a carb to the stealth ram. I have an 87 T/A and I am curious as to what all is needed to go from my motor, (former lg4 car), to the stealth ram setup? Also how much would all of it cost? Finally, how much of a gain in fuel economy would I see? I guess thats it for now, more questions will surely pop up though.
Old Jun 19, 2002 | 02:49 AM
89Irocz23's Avatar
Do a search on this it has been brought up a million times now.
Old Jun 19, 2002 | 07:33 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
well, this specific question hasn't really been addressed too many times, although eventually searching would bring up your answer.
Anyway... holley sells the stealth ram in 2 different ways. One is complete with everything you need to swap from a carb, except for the fuel pump and fuel lines. The kit includes ECM, harness, all sensors, fuel injectors, blah blah blah. The kit is $2700. The $450 kit that everybody here is buying is just the intake, plenum and rails, which is what we need to convert from TPI to the SR setup. The most affordable way for you to get into a SR is buy the $450 kit, then get the ECM & harness, throttle body & maybe a fuel pump off Ebay. Then you'll need to get any sensors that your carbed car doesn't have (which is most of them), but I'd buy those new. IAC, TPS (Used throttle body almsot always comes with these still attached tho), knock sensor (Speed density knock sensor is different than MAF sensor. I *think* carb cars use the same knock sensor as MAF cars), MAT sensor, MAF, and probably a couple more that I'm forgetting. Then it should just be little things, like throttle cable, TV cable, etc. Oh yeah... you're going to need a distributer with a divorced coil.
Old Jun 19, 2002 | 07:57 AM
Fade07W's Avatar
Okay, thanks, I came across the $2700 dollar kit later on last night. Thats really pricey. So it would definitely be much cheaper to go to a junkyard for some of the stuff. Now how hard would it be to swap from the stock wire harness to one from a tpi car? Also how does the ecm with the Stealth ram work? You just plug it into the tpi ecm? I am curious just how this configuration works because the commander 950 system looks very nice. Does anyone have experience with it?
9192camaro
16
Feb 3, 2019 12:21 AM
Mutillator
Sep 17, 2015 04:38 PM
mddaniel
Sep 8, 2015 05:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
