this is from the tech section on this site..
The original 215hp 305 TPI motor came out in 1985 available both in the Z28 and IROC-Z. The motor was detuned for 1986 losing 25hp due to a cam change.
so, if i got a new cam , i could gain back that 25 hp lost? from the cam change, i don't know much about cams, what kind would i need?
Jim85IROC
close
You could, or you could get a better aftermarket cam and make even more horsepower. Either would require a PROM reprogramming to take full advantage of the new bumpstick, however.
Jim85IROC
close
Very true, and it's always safe to err on the side of not enough cam, but there's still a good bit of room to improve on the factory cam. Summit sells a cam that claims a 40hp gain on a stock 86, although I don't have any actual experience with it, so I hate to actually recommend it.
60hp gain on a stock engine with just a cam kinda makes me want to go out and wash your sasquach
Quote:
The specs on that cam are the same as the '85 factory TPI cam, so 40 is stretching it a tad.Originally posted by Jim85IROC
~M~
so if i looked into this cam i'd be safe to say i could gain that 20-25 hp?, which cam was this if someone could post the link
thanks
thanks
Jim85IROC
close
Quote:
~M~
I didn't know that. I had no idea it was the same as a stock 85/L98 cam. I still think that you can easily get away with a little bigger cam than the 85 piece, especially if you've got headers and do a PROM reprogramming. A decent cam could probably get you 15 hp over an 85 cam, so that would be a 40hp bump over a peanut cam.Originally posted by Morley
~M~
Here is the cam from Summit.
Click to view image
$159.99
Overview
Material Cast Iron
Up to 40 more horsepower for your TPI engine
Chevy: 1985-87 Camaro 305, 350, 1985-87 Corvette 350; Pontiac: 1985-87 Firebird 305, 350, 268/278 degrees duration TPI camshaft kit
Advertised duration: 268 intake/278 exhaust
Duration at .050 in. cam lift: 204 intake/214 exhaust
Gross valve lift: .420 in. intake/.442 exhaust
Lobe separation: 112 degrees
Stuffed in an '86 IROC Camaro with a 305 TPI motor and an ADS Super Chip installed, our TPI cam kit made 40 extra horsepower and knocked almost a full second off the IROC's 0-60 times--and the computer worked perfectly. This kit includes the cam, lifters, springs, retainers, and lube. If your car has more than 30,000 miles, we suggest you add a new timing chain.
Sold as a kit.
Click to view image
$159.99
Overview
Material Cast Iron
Sold as a kit.
This is supposedly the cam that was in the '85 TPI, very close to the Summit cam. I have also seen elsewhere that the 85's cam had the same grind as the summit one.
1985 305 TPI
Lift: intake .404
exhaust .415
Duration: intake 320
(crank) exhaust 320
1985 305 TPI
Lift: intake .404
exhaust .415
(crank) exhaust 320
Jim85IROC
close
The 85 cam had the following specifications:
1985 (L69 & LB9)
Duration @ 50: 202/206
Lift (1.5): 403/415
LSA: 114.5
GM Part #14088843
87 cam:
1987 (LB9 5-Speed, L98)
Duration @ 50: 202/207
Lift (1.5): 404/415
LSA: 114.5
GM Part #10088155
88 & 89 cam:
1988 (LB9 5 speed, L98)
Duration @ 50: 207/213
Lift (1.5): 415/430
LSA: 117.0
GM Part #10066049
90 cam:
1990 (305 5-speed w/G92 & 350)
Lift (1.5): 413/428
LSA: 114.5
GM Part #10111773
1985 (L69 & LB9)
Lift (1.5): 403/415
LSA: 114.5
GM Part #14088843
87 cam:
Lift (1.5): 404/415
LSA: 114.5
GM Part #10088155
88 & 89 cam:
Lift (1.5): 415/430
LSA: 117.0
GM Part #10066049
90 cam:
Lift (1.5): 413/428
LSA: 114.5
GM Part #10111773
Jim85IROC
close
Quote:
Originally posted by highhat
Hey Jim you wouldn't happen to have the specs for an 89 350 TPI 700R4 factory cam? :hail:
From above:Originally posted by highhat
88 & 89 cam:
Lift (1.5): 415/430
LSA: 117.0
GM Part #10066049
