Casting Numbers
Old Jun 26, 2002 | 01:38 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Casting Numbers
I need some help if anyone knows these casting numbers.
After dealing with a few TPI systems now, and having fourlower intakes in my room... I've forgot which years are which.
I went ahead and got two casting numbers.
I believe the one off an '85 is : 10066016 I assume it would be the same for 86?
I also have one that says 10066013 I'm unsure of what this one is off of.
I have another 85 downstairs that I'm about 99% sure is a 85, but I haven't managed to get the casting numbers yet. I also have another one, but I haven't got to it yet.
If anyone knows the casting numbers of any of the years please let me know.
The runners I can tell the different between, the injectors I've learned, the TB, IAC Housing, and Plenum all have date stamps. The lower intake is the only one that is confusing me.
Old Jun 26, 2002 | 10:47 AM
Ions91Z28's Avatar
anyone? anyone who has a spare TPI intake laying around and knows what year it is, could you please tell me the markings on it.
Old Jun 26, 2002 | 11:19 AM
Gruvin84SS's Avatar
intake bolt pattern
easy way to tell is if all the bolt holes are the same angle. If the two center bolt holes on each side is more vertical than the other two sets then it is an 87-92 intake. If all the bolt holes are the same all the way areound the intake then it is an 85-86 intake.
Old Jun 26, 2002 | 01:25 PM
Ions91Z28's Avatar
Alright, I'll look at them and try to tell. The only probably is what if I only had one intake and was trying to tell which year?
But I'll use that method for now, if anyone has any casting numbers, please post them.
Thanks.
Old Jun 30, 2002 | 12:02 AM
troberts2's Avatar
Try this NRHA site for manifold casting numbers, and a whole bunch more.
http://www.nhra.com/tech_specs/engine/index.html#chevy
Old Jun 30, 2002 | 12:12 AM
Ions91Z28's Avatar
Big thanks for that link, exactly what I was looking for.
Can't thank you enough.
Old Oct 6, 2009 | 09:59 AM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Re: Casting Numbers
Hey if anyone else is looking for this info, the above link no longer works. This one should provide what you are looking for:
http://www.nhra.com/competition/blueprints.aspx
TPI is listed as PFI(port fuel injection) on the spec page
Old Oct 6, 2009 | 05:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Casting Numbers
Originally Posted by 87IROCZ350TPI;4305313
[URL
http://www.nhra.com/competition/blueprints.aspx[/URL]
Nice one; put that in my bookmarks
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
