question about rear-end..pleae read
Old Jun 26, 2002 | 11:57 AM
RAW ROC-Z's Avatar
First of all, i know i have a problem with my rear-end. If you place each one of your hands on each side of one of my rear wheels and move it back and forth there is some 'play' somewhere in the rear-end that makes a 'clunking' noise. Now this can be done on both drivers and passengers side rear wheels. I'm thinking along the lines of bearings????? Also, my car is an 89 iroc 305 auto...did this come with a posi rear-end???, because both of my tires spin.
Since im here..does anyone know some formulas for what a 305 becomes when you bore it over???
Old Jun 26, 2002 | 02:49 PM
Gruvin84SS's Avatar
woobly rear?
If you are taking about the wheel moving in and out slightly toward and away from you when standing in front of it, this is pretty normal for C-clip rear ends. If you have side to side or up and down wobble or if you have a clicking in the rear when you turn the tires then you probably have some bearing issues.
Old Jun 26, 2002 | 03:40 PM
Bort62's Avatar
This is the TPI board
Old Jun 26, 2002 | 03:41 PM
tpi_roc's Avatar
Yea sounds like you need a health board.
Ghettobird52
Jul 5, 2024 11:18 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
reiderz iroc
Aug 13, 2015 04:57 PM
