cam question, Need answer ASAP
Old Jun 29, 2002 | 12:00 AM
89Formula305's Avatar
Ok I have a 89 Firebird the motor is stock, its the LB9 305 TPI, 5-speed if that will help anything...
I have two questions:
I want to know...does that motor have a hydraulic roller cam?
and I found a 350 LT1 cam that I can get for cheap, its a hydraulic roller cam... will that work with my 305??
Thanks alot,
Joel
Old Jun 29, 2002 | 12:15 AM
also would it be worth it to put it in?
Old Jun 29, 2002 | 01:15 AM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
To answer you questions. Yes you have a hydraulic roller cam and yes it'll work. Check the following links for more info.
https://www.thirdgen.org/techbb2/sho...ht=lt1+cam+305
David
dutch930
Sep 11, 2015 06:58 AM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
