Accel DFI 7 ???? with stealth ram
Old Jun 29, 2002 | 08:54 PM
onebadta's Avatar
Car: 89 GTA
Engine: 383, Accel DFI, stealth ram
Transmission: 700r4, 3500 stall
Axle/Gears: 9 bolt 370 gears
Hi I'm looking into getting the Accel DFI 7 Engine fuel manegment system for my 89 GTA.... is it worth it....looks like it to me from what i have read so far....Also i will most likely be getting the stealth ram very soon ...whats your opinions with the using this system on the stealth ram????? Also Any info at all on the Accel system i woul appreciate
Old Jul 1, 2002 | 02:41 PM
Guest
Guest
Posts: n/a
As far as relatively inexpensive aftermarket engine control systems go its not bad. Look up info on just the DFI, the 7 is just an update and shouldnt make any real performance differences. As for the intake, the whole idea of the DFI is to get the fuel and timing setup for whatever you might run under the hood, so really anything, including the stealth ram, will work fine.
Old Jul 1, 2002 | 09:38 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
Originally posted by madmax
, the 7 is just an update and shouldnt make any real performance differences. .
Except for Sequential injection mode!
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
efiguy
Sep 27, 2015 01:30 PM
