Help a 17 year old girl get her car running
Old Jun 27, 2002 | 07:39 PM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
I have a 1986 chevy camaro 305 tpi Iroc-z. I drove threw a big puddle like 3 days ago. And the car stalled out and I got stuck. Then finally after pushing it out it restarted. Then it was running fine. Then the car acted like it ran out of gas. It gets no fuel to the rails so I changed the relay, still no fuel. I also jumperd the G terminal to see if the fuel pump would give power or fuel, still nothing. I refuse to think that my fuel pump went. Would there be any thing else that could be causing this. Please please help!!!
Please e-mail me at camarochic33063@yahoo.com
Thanks a bunch !!!!
Old Jun 27, 2002 | 07:43 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Post a picture. The last time someone made a post like this, it turned out to be a guy pretending to be a girl...hoping he would get more people to help him.
Old Jun 27, 2002 | 07:51 PM
camarochic's Avatar
hear i am
help help
Old Jun 27, 2002 | 08:07 PM
Car: Death Mobile
Engine: 666 c.i.
I will assume that you are not getting an SES light.
First check, do you hear the fuel pump "prime" for 2 seconds when you first turn on the key?
Old Jun 28, 2002 | 01:44 AM
Bort62's Avatar
LMAO!
Glenn you perv hahahhaha
I can't belive you actually posted a picture here. Be Careful
Sounds like your pump took a shix, or the wiring to Said Got in trouble.
Pump dosent Run at all evenwhen jumpering terminal g ?
Old Jun 28, 2002 | 03:36 AM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
Whatcha looking at?
No power huh? How much gas did you have in the tank? I found that I thought I had enough in it (Like almost 4 gallons) but that wasn't enough.
My advice is if you are getting no power your pump is dead.
Old Jun 28, 2002 | 07:24 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I had a similar problem with my 87 Formula. The Gas gauge would read in excess of 1/4 tank, but there would be no gas in the tank. Put some more gas in it and see what happens.
Have you tried by-passing the relay? You should be able to hear the fuel pump kick on when you turn your key top the "On" position. If it doesn't start after you check all of this, you have to gank the rear and replace the pump.
Old Jun 28, 2002 | 08:03 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
check the 3 wire connector at the tank under the car. It could very likely have gotten fouled. Mine has a couple times.
Old Jun 28, 2002 | 08:38 AM
Car: Death Mobile
Engine: 666 c.i.
Originally posted by Bort62
LMAO!
Hey, it got a picture posted and a number of responses (all suggesting the fuel pump or wiring).
Old Jun 28, 2002 | 09:39 AM
camarochic's Avatar
does any one know of
Is there any one in the ft. lauderdale area that can do a fuel pump cheap. Cause I don't have a lot of money. I'll buy the fuel pump I just need it in. thanks a bunch!!!:hail: :lala:
Old Jun 28, 2002 | 09:50 AM
tpi_roc's Avatar
Hahah
The fuel pump is about the ONLY thing that I WOULDN'T do for a friend. That is a job that truely sucks.
Old Jun 28, 2002 | 10:17 AM
Bort62's Avatar
Some friend you are!
I just Did it Twice for the same friend In the course of a week
IN all actuality, Its not all that bad. The second time was with air tools and My other friend to Help Me. Had it out in abou 15 minutes.
Apart from wating for parts, whole job was done in about 1 hour.
If the pump isnt kicking on, Its either dead or there is a voltage problem upstream.
Regardless if there is enough gas in the tank or not.
Use a DMM and check for voltage with the key in the on position at the 3 wire connecter, on the brown wire with the white stripe.
If you want, you Can pull around a bit at the carpet between the two rear seats and use that to get at it without getting under the car.
Still the brown wire with the stripe. The black is ground and the Pink is for the fuel sender.
If your not getting voltage, or getting insufficent voltage, something is fuxored upstream of the pump.
If your getting 11+ v at that point, I would be willing to bet the pump is gonzo.
Don't drive through puddles
Old Jun 28, 2002 | 10:18 AM
BitchinCamaro's Avatar
Go over to Fl-thirdgen.org, I know there are a couple guys in your area who would probably stop by and help you figure out for sure what the problem is for sure. Also ask around for a shop on the regional boards. Just make sure whoever does it drops the tank and doesn't just cut a hole in your floor pan.
Old Jun 28, 2002 | 10:19 AM
Brad's Avatar
LMAO. This is classic
Old Jun 28, 2002 | 11:41 AM
Morley's Avatar
The tank isn't so bad to drop, especially if there isn't much gas in it. The "hardest" part of it all is getting the fuel neck back up in the hole when reinstalling. A bottle jack and a 1' X 1' piece of 1/2" plywood make the job much easier. If you had all the parts right there the job could be done in a couple of hours.
A quick question, how deep was that puddle? And did you pull out the air filters after you went through it to make sure the car didn't injest water? If it injested water, then you probably fried the MAF too
~M~
Old Jun 28, 2002 | 11:42 AM
Morley's Avatar
A fair assumption, seeing as the car won't run to get a light
~M~
Old Jun 28, 2002 | 12:27 PM
ede's Avatar
ede
hey glenn i'm no expert but it looks like a chic to me, maybe you ought to the mick dundee test like he did in the bar scene in the first croc dundee movie.
Old Jun 28, 2002 | 01:01 PM
HighHopes85's Avatar
Damn...you can do all that troubleshooting with just a picture? I outta send you a pic of my MEMCAL
Old Jun 28, 2002 | 01:12 PM
craiger's Avatar
Deeaaam! Next time I need some help with my Z, I'm gonna post as a girl den, put my wife's pic in
Old Jun 28, 2002 | 01:29 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
hah :sillylol:
Anyway... my old man had that problem once, turned out the force of the water going under the car disconnected a relay.
Old Jun 28, 2002 | 02:32 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
ive been through a few "puddles" that were deep enough to float the rear of the car..it stuttered a little bit and idleed rough for about 30 seconds and the clutch was hard to engage but then it was fine..
id say check the air filter and hope u didnt fry the maf..then check the relay behind the rear seats and hope thats your problem...
and put some more gas in it to find out...
my pump went south and cut through the rear hatch area to change it....my exhaust is welded at the cats so i couldnt disconnect it so i had to, but my buddy arc welded it so u cant even tell
lmao@post your pic
Old Jun 28, 2002 | 04:32 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Before you go rippin' the fuel pump out, check the fuse at the front of the engine bay, it's mounted on the radiator support just behind the driver side headlights. It's a little black box with 2 heavy orange wires coming off of it, if that fuse is blown your fuel pump will not get power.
Old Jun 28, 2002 | 04:58 PM
camarochic's Avatar
I checked all the fuses and they are all fine. Is there anything other than the fuses and the fuel pump that it could be. please please help I really need to get my car running Is there any one in ft.lauderdale florida that is willing to help me with my car. I can pay a little and I am willing to trade something. I have lots of parts and alot of other cool stuff to. Thanks a bunch Patty:hail: :hail:
Old Jun 28, 2002 | 05:14 PM
Bort62's Avatar
You won't know anything untill You check for Voltage at the Pump.
And I wouldnt offer any "Trades" On this board, you never know what you will get.
Old Jun 28, 2002 | 08:05 PM
Don_89Iroc's Avatar
i agree w/ Bort on that one, i mean just look at Borts location by the way your cute patty hope you get your car running soon!
Old Jul 1, 2002 | 01:10 AM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
nice smile and rack, heheh.
i can say that, i'm not an old man, i'm 22. =D
happened to my friend too, new pump, although he always ran his tank to empty too, not good.
i don't live in FL, sorry!
Old Jul 1, 2002 | 09:14 AM
IROC57TPI's Avatar
What kind of F-Body owner in their right mind would drive thru a puddle? I mean, I avoid any water in the road, not just the deep puddles.
What- you think you own a truck or something...?
Old Jul 1, 2002 | 10:16 AM
DakotaSLT's Avatar
[i]
What- you think you own a truck or something...? [/B]
I do, and with 9" of ground clearance over the rear differential I fear no puddles. If she did get any trouble codes before it died though, it might be worth renting a code reader to see if there are any clues there as to what needs to be fixed. But it does sound like the pump, sucks, but sometimes the PITA jobs are necessary.
Old Jul 1, 2002 | 10:02 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Well Camaorchic as someone mentioned , it may be the fuse located by the rad on the passengers side of engine bay. Also check to see if your oil pressure sending unit by the oil filter is plugged in. The water may have loosened the connection or maybe broke it? Does the fuel pump relay have power to it? Does the fuel pump fuse have power? ( not the fuse under dash ) If both have power, and your oil pressure sending unit is intacted and working. Then either you are out of gas or the pump went for a S&%t! Hope it is the lessor of the 4 posabilities. Sending units for the oil aren't to expensive, or hard to replace...Fuel pumps probably gonna cost ya$$. Hope you find a nice,helpfull person nearby. Hope this helped
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
