I need to ID which of these is the Carbon Canister purge solenoid?
Old Jun 30, 2002 | 07:36 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
I have several solenoids in my garage and can't figure out which was the CCP solenoid. The two I have narrowed it down to both have only a 2-wire connector.
But one has only 2 vacuum ports, 1-input, 1-output. and says CAN where the vac tubes would plug into, has #4224 1 on it as well as 201.
The other has 2 vac ports, but also has another tube that appears to be a "release" of some sort because I can blow in it and air comes out 1 of the ports, and air can be sucked thru it from the "release" tube, it does not look like a vac tube is supposed to go on this extra tube.
Old Jul 13, 2002 | 12:31 AM
93ND500's Avatar
if you still need to know.......the one that says CAN is the one for the CCP. The other one is for EGR soleniod.
Old Jul 14, 2002 | 01:08 PM
2QUIK6's Avatar
Thanks Will, I tried wiring in that one to the TPI ECM and I think I've figured out that the one that was originally on theTBI is not the same as the TPI one, appears that it is pulse width driven but can't get it to open from the ECM and I can only get about .3v thru the circuit on a voltmeter, but if I ground the wire instead of feedign it back tot he ECM, it opens right up fully.
I had it wire from the ignition power wire on the ECM and the other wire going to F7 which should pulse width ground it I think.
I'm going by the dealer tomorrow and see if they are the same or not before I go any further with it.
grngryoutmyway
Oct 18, 2016 05:48 PM
Quzyle
Oct 15, 2015 03:35 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
