Smog Pump. WA State Emissions, Makes cat build up?
Old Jul 2, 2002 | 11:42 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
The Smog Pump on my '85 305 TPI started making a horrid noise. It didn't sound like your classic bearing going out noise. It was almost like an exhaustleak mixed with a lifter. Weird no? Well spend the $51 to get a remanufactured one.... or take it off? Will I pass DEQ? I've also read here that if you don't have the air equipment on, your cat builds up with crap from it? And truth to that?
I know you wont pass DEQ in Cali, but this is Washington...
Old Jul 3, 2002 | 11:06 AM
iroc22's Avatar
I don't think it's true about the cat getting clogged up. If you get a 3 way replacement cat, you will be able to pass emissions without your smog pump.
Old Jul 3, 2002 | 05:41 PM
So my 3" Catco wont pass with the pump off?
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
backtothe80s
Sep 5, 2015 12:39 AM
sreZ28
Aug 14, 2015 07:48 PM
92camaroJoe
Aug 13, 2015 06:07 AM
