Let me make sure I have this correct...
Old Jul 3, 2002 | 01:41 PM
viperwsu's Avatar
Car: 91 Camaro RS
If I install a higher lift and duration cam into a stock MAP TPI setup, without burning a new prom, the vacum will decrease, causing the ecm to release less fuel, and consequently making the engine run lean, which the ECM won't correct despite readings from the O2 sensor. Is that accurate, or am I wrong? Thanks.
Old Jul 3, 2002 | 02:45 PM
ImportsRsloths's Avatar
Well to a certain extent.....
If you put the summit TPI cam in with like .450 lift it wont be very noticeable if at all
if you put an lt4 hotcam in there..... that will be a different story!!!
Old Jul 3, 2002 | 05:52 PM
89Irocz23's Avatar
exactly true somewhat. We need Vader to come help
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
