Can a stock lt1 cam work in my 305tpi?
Old Jul 4, 2002 | 11:10 AM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Just what the topic says!!
Old Jul 4, 2002 | 12:04 PM
85maroz28's Avatar
ttt:lala:
Old Jul 5, 2002 | 12:29 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
try doing a search you'll get more answers.
to answer your question it will work in your 305,but you need to tap the dowel pin at the front of the cam shaft in a certain depth.if you don't that dowel pin will tear into you timing chain cover.
Old Jul 5, 2002 | 09:08 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
will it work? sure, with modification, but there are plenty better cams out there for a LB9..
Old Jul 5, 2002 | 09:16 PM
85maroz28's Avatar
I know but I am getting if for $30. I figure that was a grod deal??
Old Jul 5, 2002 | 10:47 PM
89Irocz23's Avatar
yeah thats a good deal, but if you have the l98 cam its not gonna be worth the hassle of changing cams. If you have the peanut cam then oh ya it will be worth it. You'll have to take that pin off the end so it dont put a hole in your timing cover but other then that it will work.
Old Jul 6, 2002 | 12:16 PM
91banditt2's Avatar
Engine: 5.7 HSR
another thing...well two things
i'm not sure if you can use a roller cam in a non-roller block.some body else mite know
?-1986 non-roller 1987-1997 roller
you don't want to remove the dowel pin you just want to tap it in untill it sits flush with you cam gear for you timing chain.
Old Jul 7, 2002 | 09:01 AM
camaro6spd's Avatar
yes...87 was the start of the roller cam equiped blocks. I know summit used to have a good cam for the 85-86 IROCs.....it was made just for them...call them up and ask about it...i know a few people on here have used it and they said that it gave them a nice improvment.
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
Thirim
Aug 9, 2015 06:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
