car running hot, help on stat ?
Old Jul 6, 2002 | 08:56 AM
TransAm87's Avatar
I know that i am going to do my cooling fan mod today, but what thermostat should install, its my daily driver and it runs to hot, usually runs around 220, i dont know what stat is in it now, but i gotta run to advance in a few hours to put a new one in, what stat should i put in..thanks
Aj
__________________
Old Jul 6, 2002 | 07:40 PM
gmanrs70's Avatar
I own an 87 350 TPI and am running the stock 192. I'v heard alot of guys are starting to run 180 but don't run a 160 unless you are going to change your prom. Hope this helps.
Old Jul 7, 2002 | 09:03 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
thermo
run a 180 stat and drill 2 1/8 inch hole in the base plate of the thermostat.....
Old Jul 7, 2002 | 09:47 PM
TransAm87's Avatar
what is the hole for?
Aj
Old Jul 7, 2002 | 11:08 PM
Swapmaster's Avatar
He means drill two seperate 1/8" holes in the outter frame of the
thermostat. This will allow some coolant flow even when the
thermostat is closed. It also keeps steam and air pockets purged
from the block, it's an old racers trick but it works. I usually drill
one hole in any thermostat I install, except for some Fords that
already have an air vent in them as a stock item.
Customer cars get one hole, personal cars get two holes and I
put three or four in my hot rods depending on how quickly they
get hot.
Old Jul 8, 2002 | 05:00 AM
TransAm87's Avatar
wow, i have to try that trick, now where do i drill these holes.
thanks
aj
Old Jul 8, 2002 | 09:01 PM
Swapmaster's Avatar
Drill two holes in the thermostat flange between the center hole
and the outter edge that contacts the manifold.
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
Irocohio
Aug 12, 2015 08:03 AM
Kaweh
Aug 9, 2015 02:54 PM
