TPI on a 400+ ci motor ?
Old Jul 6, 2002 | 08:13 PM
egmonster's Avatar
I was wondering if this is a feasible thing. I am still trying to decide exactly how much I really wanna invest in the engine. I may end up going for a zz4 with forged pistons, but I am also considering the possibility of a 400+ based on a Dart Little-M or World Products block. I want to keep it pretty stock looking though. I have already decided that I am going to keep the plenum and AS&M runners and invest in the edelbrock TPI base and port the heck out of it. I was wondering if this setup can flow enough for all those cubes... What kind of #'s I should expect say vs an LT1 intake. I'm looking long and hard at AFR 190's. If I went with a bigger motor I would go with AFR210's. Any input is very valued and appreciated thanks .
Old Jul 7, 2002 | 12:00 AM
Gta-Paladin's Avatar
i think 190's would be to small for a 400 cui but then again you're putting tpi on it so i couldnt say... And anything is possible expect monster torque though
Old Jul 7, 2002 | 12:22 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I would really go with the LT1 intake or Mini Ram if you don’t have to pass emissions. To use TPI on a 400 you will have to buy an aftermarket base and runners and port the whole intake. TPI was originally designed for a 305, so if you want to use it on a 400 you are going to have to do a lot of work to it or else that engine is going to be starving for air. You should also consider the Super Ram; it is emissions legal and flows well.
If you want flow benchmarks search the form they have been posted before.
Old Jul 7, 2002 | 04:21 AM
egmonster's Avatar
Well to be honest I love the look of my stock TPI intake. I think I am just going to have to do major porting . It's also nice to have that "basically stock" look as well . I saw a guy on this board cutting 1.6 60' times and hitting high 11's low 12's @ around 110! Thats with AFR 190's, edelbrock base, AS&M runners and stock plenum. Siamsesed and Ported thoroughly. That was on a ZZ4 block.
1992rs/ss
Jan 31, 2025 05:10 PM
Steve78LT
Feb 24, 2016 12:15 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
Vintageracer
Aug 11, 2015 08:13 PM
