mismatch intake parts
Old Jul 14, 2002 | 02:40 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
i have a couple questions for u guys....what manifold base is the better one....accel''s superram, eldelbrocks, or tpis's bigmouth....whatever one i get i will siamese it for a little more umph.....and can u use any companies runners on n e other companies manifold base...thanks guys!!
Old Jul 14, 2002 | 02:44 AM
Morley's Avatar
Re: mismatch intake parts
Whichever is cheapest since you plan on porting it a bit anyway. And yes, the runners from one company will fit another's base since they all claim to fit "stock" manifold bases they are all inter-changeable.
Old Jul 14, 2002 | 02:49 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
that solves that..lol thank you!
Old Jul 15, 2002 | 02:53 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
what base would flow the best out of the box
Old Jul 15, 2002 | 11:49 AM
tpi_roc's Avatar
TPiS's probably since I believe its a ported edelbrock?
Old Jul 15, 2002 | 11:44 PM
Morley's Avatar
Supposedly, yes. There again the TPIS is probably the most expensive to.
Old Jul 19, 2002 | 06:47 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i looked at tpis's site the other night and there bigmouth is 425 edlebrocks is 459 and the same for the accel base...so i guess its the tpis if its a ported edlebrock thats even better! alls i have to do i siamese it
Old Jul 20, 2002 | 11:01 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
And for $400 you can get John Millican's modified LT1 intake which will be the last intake mod you'll ever have to do. www.lt1intake.com
PS: Don't believe the people that say it will kill your bottome end torque. I just installed a Miniram (which the LT1 intake basically is) on an otherwise stock engine. I have MORE torque < 2,500 rpm than I had with the TPI setup. And this is without an optimized eprom (that I had for my TPI setup).
I would say I loss a little (and I do me very little) torque from 3,000-3,500 rpm, but everywhere else its more. Especially after 4,500 rpm. I can now add a cam and have the engine make some REAL power.
Old Jul 20, 2002 | 11:42 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
even without personall experiacne i know that losing low end torque is lt1's make there peak torque at 2400....whats the diff between his and a stock lt1 manifold....how much of a torque and hp increase will u get from this conversion....and what does it intail....just a bolt on or what?
Old Jul 21, 2002 | 11:11 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Glenn,
Have you had problems with coolant? I have heard horror stories of people having coolant leaks into there oil.
Also f-crazy,
Selling your TPI intake will cover most of the cost of your LT1 intake.
Old Jul 21, 2002 | 09:59 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i kinda want to keep my tpi setup...i wanna fully siamese it and do some runs with it then do the lt1 swap...how far in can i siamese the stock runners on the tpi? it looks to me no more then 3/4 of an inch on the top maybe a little more on the bottom...can i use my 19# injectors on the lt1 manifold and is there any porting siameseing that can be doen on the lt1 manifold?...thanks guys!!
Old Jul 21, 2002 | 11:01 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
quick question...with the lt1 manifold what cam would be better suited to it...the lt1 cam or comp cams xr252-hr-10
int lift .472
exh lift .480
lobe center 110
252 int duration
254 exh duration
one thing im not to sure of...i know what lift and duration is but how does lobe seperation acceft the cam?...the lobe serparation is the degrees from the center of one lobe to the next correct?..and how does differnt angles affect idle power etc...
most of the cams i see have 110 to 114 whats the differece?
Old Jul 23, 2002 | 10:00 PM
89Irocz23's Avatar
lt4 hot cam would be sweet with a lt1 intake setup. Thats what im wanting to put in later. My lt1 is almost ready to run. Alls I need to is hook up new battery cables and run my collant lines and I should be ready to go. Im still waiting on my battery and battery bow to put it in the hatch area.
Old Jul 25, 2002 | 11:44 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
its a 305 so with my stock rockers it wont be as bad cuz its made for a bigger motor
im going to port my heads to make better use of the new intake
and cam..
what about siameseing the stock runners
Old Jul 29, 2002 | 03:19 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
You should probably do all that stuff if you're gonna build a 400 horse 305.
Old Jul 29, 2002 | 05:39 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
due to many restrictions im not goin for 400 ...i tossed that number out there to see wha tit would take....right now im lookin at 325-350 and with a cam ported heads and a lt1 intake i think ill be there....so should i keep the stock rockers or go after 1.6's and diffeernet valvecovers
Old Jul 30, 2002 | 12:28 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
will a 305 be able to pull a lt1 manifold with a comp cams xr 252 and fully ported heads
Old Jul 30, 2002 | 01:03 AM
tpi_roc's Avatar
like the subject says
1992 Trans Am
May 10, 2023 07:19 PM
masonta
Aug 31, 2015 10:14 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
