SVO 24lbs Injectors work in 3rd gen?
Old Jul 14, 2002 | 11:55 PM
92zeddar's Avatar
Will the ford SVO 24lbs injectors work in our 3rd gens? just wondering because they are always cheaper..
Old Jul 15, 2002 | 12:57 AM
dakkon's Avatar
yes
Old Jul 15, 2002 | 12:58 AM
kevinc's Avatar
Car: 1982 Z28
Yes they fit, but to get the engine running efficiently you'll need a chip burned with the injector rate set to match. Some people have been able to dial down their fuel pressure and run OK, others have run horribly until they got the software set correctly.
Old Jul 15, 2002 | 02:39 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
yes the 24's will work. and like said above, u will need to make sure everything is running efficently. im going to be putting soem 30# SVO's on my 406 *sooner or later* and ill have to get another chip burned and drop my fuel pressure down to soemwhere between 43-47 psi *its at 59-60 now.
Old Jul 15, 2002 | 09:16 AM
92zeddar's Avatar
I was pretty sure they would work but just wanted to MAKE sure..as for chip burning no problem I have all the stuff to make my own.. thanks again guys.
Old Jul 15, 2002 | 06:47 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Make sure you get the SVO injectors for the late 80's/early 90's stang. The newer style injectors are different and will not work.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
