aHHH too many trouble codes!
Old Jul 16, 2002 | 01:46 PM
TunedPortZ's Avatar
i was checking the codes on my car and i got a code that said that the mass air flow sensor was getting too much air something of the sort. i forget the code number but it doesnt make any sense to me. also i got one about the vss (vehicle speed sensor) the in the world is that. also got one about it running lean, and another about the egr valve. if you guys need more info i will find it out but im sick of my stupid check engine light coming one.ive been around this car a few times but it just keeps becoming more greek to me.
Old Jul 16, 2002 | 02:55 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
IT would be alot easier to help if you could post code numbers and what the code means.
Old Jul 16, 2002 | 10:48 PM
Swapmaster's Avatar
Code numbers will help but it sounds like you have a vacuum leak
somewhere.
Old Jul 17, 2002 | 10:02 AM
tpi_roc's Avatar
A vacuum leak should register to little air if he has his code right.
If your VSS sensor Is dead or unpluged that would explain the rest of the codes, does your speedometer work?
Old Jul 17, 2002 | 01:47 PM
TunedPortZ's Avatar
yeah the speedo works, ill find out eactly what codes the thing is spitting out
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
