LT1 intake: how long for fuel lines?
Old Jul 19, 2002 | 04:12 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
LT1 intake: how long did you make your fuel lines?
I just wanted to know how long everyone running LT1 intakes got there fuel lines and how much did it cost? Thanks,
Chris
Old Jul 22, 2002 | 10:22 AM
tpi_roc's Avatar
www.lt1intake.com
Old Jul 22, 2002 | 10:49 AM
Car: 1991 Z28
IT doesnt say anything about how long the fuel lines should be. but thanks TPIroc
Old Jul 22, 2002 | 10:50 AM
tpi_roc's Avatar
If anybodys going to know the length he will.
Old Jul 22, 2002 | 02:55 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I make them per customer request for length. It all rally depends on how you want it routed and if it's going into a F-body, Y-body or what.
The standard for a F-body is 3 feet long each. That gives you plenty of room to run them around the brake booster and away from the exhaust.
Chris,
If yours are too short or too long send them back and I'll exchange them for free.
Old Jul 23, 2002 | 07:19 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
John, I'm thinking about ordering one of your intakes. What are my choices for heads, I was thinking the LT1 head had the vortec style raised port? Do they have the same bolt pattern? Can you use vortecs?
Old Jul 23, 2002 | 12:21 PM
tpi_roc's Avatar
ahem....
SEARCH!
You can use any head with the standard intake and bolt hole location...
the LT4 intake is the one that matches the vortec/fastburn.
Old Jul 23, 2002 | 09:05 PM
Engine: 4.0L
Thank you roc.
Old Jul 23, 2002 | 10:43 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
My bad my bad, yes I CAN be a lazy bastard.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
