Cam for a Stealth Ram
Old Jul 24, 2002 | 03:34 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Any thoughts on a cam for a Stealth Rammed 350? Current mods are as follows:
World Torquer heads 2.02/1.60 valves
Edelbrock TES w/ 3" exhaust
52mm TB
2800 stall converter
3.89 gears
Old Jul 24, 2002 | 03:39 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Mine is on order custom grind from comp cams and my combo is fairly similar....
Lift is .560 at the valve with a 1.60 rocker which
equals .350 lobe lift. Lobe sep is 110. Intake centerline is 106
degrees. Duration at .050 is 224 degrees for both intake and
exhaust.
Old Jul 24, 2002 | 07:58 PM
Ricktpi's Avatar
How did you arrive at that cam ? Did Comp reccomend it ?
Old Jul 24, 2002 | 08:43 PM
JMatlock88's Avatar
Car: 1991 Formula
A friend of mine with some fancy dancy $3500 software tested a BUNCH of grinds that he has been successful with on other combos. This one yielded great power (503HP), pulled to 6500, and pulled 14.9" of vaccum. All of this on pumpgas and 10.3:1. He owns Legace Performance in Arizona.
Old Jul 25, 2002 | 08:18 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
We need more info than that to pick a cam for you. What are you looking for out of this car? Is it a daily driver? Do you care about gas mileage, driveability, and emissions? You have a custom ECM, so the chip problems are taken care of... There is not a universal cam for everyone with a stealth ram...
Stangski09
Nov 14, 2015 01:27 PM
Jorlain
Oct 8, 2015 01:57 AM
R3500
Sep 8, 2015 10:12 PM
09ave
Sep 7, 2015 06:03 PM
masonta
Sep 1, 2015 06:40 PM
