FORD SVO Injectors
Old Jul 24, 2002 | 08:52 PM
primo's Avatar
FORD SVO Injectors
Can Ford SVO 30# injectors be used with a GM TPI setup, Do they have the mounting and dimentions as the stock GM injectors.
Thanks for your answers.
Old Jul 24, 2002 | 09:06 PM
89Irocz23's Avatar
Yes they work fine, but what are you using 30s for? I home its at least a 383 or a 400 cause you dont neec injectors that big. I have 24s on mine and there plenty, but yes to answer your question they go right in. You may need some prom burning but thats no biggie.
Old Jul 25, 2002 | 02:31 AM
Odyssey's Avatar
SVO injectors suck. I had a brand new set of 24# pounders.... and they all started leaking after a couple of months. That's why my next set is Accells.
Old Jul 25, 2002 | 07:44 AM
primo's Avatar
Yes, they are for a superram 383. It 'll be interesting to know which brand is better and why.
Old Jul 25, 2002 | 10:50 AM
Guest
Guest
Posts: n/a
Yea, they must suck pretty bad, being made by Bosch and all...
BTW, in case you didnt know, Accels are made by Bosch too. Getting Accel wont help you get away from the manufacturer that made your SVO injectors.
There is no 'better brand'. With 30# injectors though, you MUST reprogram the chip. There's no choice in the matter. They fit fine in the stock location, just make sure the o-rings are correct (some earlier ones had small o-rings that would not seal properly) and you're good to go. If the o-rings arent right, just get a set of new GM ones. I'd make sure to use the clips too, even though many dont.
Old Jul 25, 2002 | 01:29 PM
primo's Avatar
How about the plug, will the GM harness plug in to the SVO injectors ?
Old Jul 25, 2002 | 01:34 PM
Max_Maro92's Avatar
Car: Purple Haze Metallic 92RS
Engine: Super-ram 383cid
Transmission: race prep 700R4
30lbs injectors?
Thirty pound injectors are awefully big I'm running the 24 lbs speed pro injectors at around 60 to 65 psi and I'm able to make 450 hp with my super ram 383 and I've got 11:1 compression and a really good flowing head. When I built the motor I did a lot of reasearch on the subject of injector sizing, and learned quite a bit, you might want to give TPIS a call and see what they think www.tpis.com or 1(612)448-6021
-Mike
Old Jul 25, 2002 | 02:07 PM
Guest
Guest
Posts: n/a
Same same.
Old Jul 29, 2002 | 03:00 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
i have accel 26 lb injectors in my 406 now.. and im shopping at ford dealerships for soem 30 lb'ers.. but hey.. i need them, unless u are makign soem serious HP 24 or 26's r more then enough.. BTW i have some 26's for sale only 2000 miles on them.
* i love they conversation i have with these parts guy..
me: hey, i need some 30 LB svo's red...
sales guy: ok..*types in computer* .. for what kinda car
me: 86 iroc
sales guy: huh: ? a camaro..
me: yea.. and the 500 hp 406 thats in that camaro
sales guy: oh.. :hail
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
