belt size
Old Jul 27, 2002 | 08:30 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
Transmission: 700r4 race built
Axle/Gears: 4.10 posi
belt size
i have an 86 iroc 335tpi, switched from v-belt to serpentine belt, want to know what size belt i would need to get if i have no a/c or smog pump, and how to run the belt. the only way i can figure it out is if the water pump turns the wrong way!!!
Old Jul 27, 2002 | 08:38 PM
cobrakiller1989's Avatar
this might help
https://www.thirdgen.org/newdesign/t...rpentine.shtml
Old Jul 27, 2002 | 08:44 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
a little but i also do not have an a/c
Old Jul 27, 2002 | 08:45 PM
you have the AC delete pulley tho, correct? i dont think you can route the serpentine setup with that pulley there
Old Jul 27, 2002 | 08:53 PM
tpi iroc's Avatar
Car: 86 iroc
Engine: 355 400hp
ok, i see how to do it now. thanks for your help. do you know what size belt it is?
Nervous2
Oct 8, 2015 10:53 PM
scottmoyer
Sep 20, 2015 11:54 AM
iroczguy86
Sep 13, 2015 02:22 PM
m00n420
Sep 11, 2015 02:39 PM
MORREALE5
Sep 10, 2015 08:58 AM
