Plenum porting
Old Jul 29, 2002 | 06:04 PM
DOOSKI's Avatar
Car: 1990 Trans Am GTA
Engine: 5.7 TPI 350 sd
Transmission: A4
Plenum porting
Can anyone explain how to port a plenum because i´m buying TPIS large tube runners and they are going to flow better if i fix the plenum. And i will ad an AFPR, anyone were i can get a new one cheap?? what gains will i see on stock 350?
Old Jul 29, 2002 | 07:11 PM
DownUnderIROC's Avatar
Go here http://members.optushome.com.au/iroc-z/downloads/ and download the plenum.pdf file.
Old Jul 30, 2002 | 11:26 AM
iroc4ever's Avatar
Car: 1989 Iroc-Z
Axle/Gears: 2.73 (for now)
Thats a really good article... I was searching through
previous posts and found lots of other info on porting the plenum but I still have 2 questions...
1. The gaskets (FelPro 93035-1 or GM equivalent)
Where can I buy these?? And are they necessary?? Couldn't I just reuse the old gaskets???
2.The torque specifications??? How do I know if I tightened the bolt 15ft/lbs?? I usually just tighten things till I can't tighten them anymore
Old Aug 4, 2002 | 01:17 AM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
As for your second question you should be using a tool called a torq wrench. They're not cheap though. Try borrowing one from someone you know.
Remember don't steal one that would be wrong. JK
Old Aug 4, 2002 | 02:53 PM
iroc4ever's Avatar
Car: 1989 Iroc-Z
LMAO yeah I was kinda thinking that might be the tool I'm looking for
Reid Fleming
Oct 10, 2015 09:56 PM
toronto formula
19
Oct 6, 2015 12:27 PM
bplessy
Sep 30, 2015 12:14 PM
