maf sensor
Old Aug 1, 2002 | 10:57 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
maf sensor
i was reading in another post where Ed Maher said that the maf on someones car was not maxed out. if it were what other options would there be for a 350 (or 383).
Thanks, matt
Old Aug 2, 2002 | 12:40 AM
FstBrd6point3's Avatar
I think you can get MAFs from a forced induction car like a buick turbo or somethin, but you may need to put in resistors to change the voltage levels to an acceptabel range for TPI... I am not positive, burt there has been some post going around about it
Old Aug 2, 2002 | 01:41 AM
tpi_roc's Avatar
I believe there are translators for the lt1/ls1 mafs
Or you can get a wells maf
Old Aug 2, 2002 | 10:56 AM
Guest
Guest
Posts: n/a
I'm not aware of any translators for a TPI setup. Doesnt matter much anyway, even if you did install a MAF that could read to 1500CFM, the computer is still limited to around 440 (whatever 255gm/sec translates to) and you'll still have the same problem as before. About the only thing it might do is free up some restriction in the intake tract. Doesnt sound like a good $/benefit ratio to me.
Old Aug 2, 2002 | 03:46 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
by computer do you just mean the EPROM or the whole ECM. cant that be upgraded, especially the EPROM?
thanks
Old Aug 2, 2002 | 03:57 PM
Guest
Guest
Posts: n/a
Well if you find a simple way, I think alot of people will want to hear about it. Thats why you see all the SD praise running around here.
Old Aug 2, 2002 | 11:51 PM
u r sofa king we tah did's Avatar
i have seen a translator on ebay once for maf tpi cars, it was listed as a performance corvette part. i only saw it once and it was after the auction was over so i didnt get a chance to get it.
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
