LT1 Intake question
Old Aug 5, 2002 | 06:04 PM
85350TX's Avatar
LT1 Intake question
Alright I am sure this one has been beat to death but I already did a search and did not find what i was looking for so here goes. the TPI intake is a four piece intake right lower, upper, and right and left side runners? When you convert to the LTI does this replace everything besides injectors, and throttle body? Little help guys here I am ignorant.
Old Aug 5, 2002 | 06:23 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
re:
Well, the LT1 intake reaplaces all that and the fuel rails/injectors. You can use your injectors over, but you'll have to use the LT1 fuel rails. You CAN use your TB over though I believe. Try this link for more info:
www.lt1intake.com
Later, hope this helps ya!
Old Aug 5, 2002 | 07:34 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
You are correct. LT1 replaces lower intake, runners, plenum, and fuel rails. TB is reuseable, as are injectors.
Old Aug 5, 2002 | 09:34 PM
bigals87z28's Avatar
Car: Check The Sig
while this is goin... i was gunna buy (steel) a LT-1 intake...but as i remembered... and i ask now.... where the hell do u put the distributor? do i need to get the opti-spark?... heard bad things about that and i dont belive it will fit... do i need to drill a hole, and is there even enuff space to drill?.... thanks
Old Aug 6, 2002 | 08:54 AM
85350TX's Avatar
On the LT1 intake site is says you have to get the later smaller distributor 87and up or 88 and up just look on the site very informative.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
