Can a 89 TPI Base go on an 87?
Old Aug 12, 2002 | 11:00 AM
5SIZ's Avatar
Car: 1987 IROC-Z
I have the base from a 1989 350 TPI setup & I wanted to Siamese it and drop it in my 305 setup, would this be a clean swap???
I know the 89 didn't use the 9th injector but I am pretty sure there is a hole for it because the 89 runner has a plate that covers the hole. Was there any difference between the 89 base and the 87 base besides the 9 th injector that I will run into?
Old Aug 12, 2002 | 12:21 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's the same base.
Old Aug 13, 2002 | 08:23 AM
Perry93TransAm's Avatar
Car: 97 WS6 T/A
Engine: LT1 383
I'll second that, a freind of mine swapped a 90 base onto his pick-up that was using all the upper stuff and the wiring harness off of an 86!
Perry
Old Aug 14, 2002 | 09:59 PM
cdartz's Avatar
Re: Can a 89 TPI Base go on an 87?
I am running an 89 base along with the 89 chip in my 87 (long story - engine swap). You are correct that the runner has a plate where the injector hole would be. As far as we could tell the 89 base we used did not have the hole in it for the injector. It's the whole reason I went looking for the matching 89 runner and chip.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
Sanjay
Aug 12, 2015 03:41 PM
