CAI questions
Old Aug 13, 2002 | 10:08 PM
cael's Avatar
CAI questions
I've seen a lot of articles about how to make your own cold air intake system, but the most they say is that it "pulls harder" at "extreme speeds."
Can anyone quantify (or even guesstimate) the gain/loss of a "move the batter and stick a K&N cone filter there" type of air intake? Some say it works a lot better, some say it hurts because of the extra twists and less-direct flow into the engine.
Thanks!
Old Aug 13, 2002 | 11:14 PM
Jay87Z's Avatar
Car: 2000 Corvette FRC
Transmission: M6
On a TPI Camaro, you are better off making a ram air setup with the stock airbox.
The home made CAI's behind the lights are only needed by Firebirds and Camaros that weren't originally TPI cars and don't have all the intake ducting in the nose.
Old Aug 14, 2002 | 01:56 PM
cael's Avatar
Is there still a benefit of moving the battery, then?
Old Aug 14, 2002 | 10:15 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Depends how you make it, if you go buy Dryer hose and some PVC pipe, maybe a lil duct tape like some people. It will be almost exactly the same as stock. and depending on where the filter is, it wont be a "Cold Air" induction, you need something to block the Engine heat.
Mine pictured below will let the engine breather alot free'er its 3" pipe with mandrel bends in it, air will flow super smoothe rite into the throttle body, the filter will go where the stock filter was and i have plexi glass to make a heat shield around it like you see on a lot of the impalla SS's
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
