need help on pressure regulator
Old Aug 11, 2002 | 12:09 AM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
my car has been having drivability prob. (long cranking startup, some stumbling) and i thought it was the fuel pump, but i am not so sure anymore, because i did the flow test , of wich in 15 seconds, it is to flow 1\2 pint, that is equall to 1 pint in 30 seconds, i got 1 pint in 22 seconds. i think that is to much. and also, i put a press. gauge on it and the pressure will slowly rise to about 4 psi and then fall, when i manually turn on the fuel pump. so could it could the press. regulator be bad?
if it is bad, i know the plenum needs to come off, but can i leave the runners on? i need all the help i can get.
thanks
anthony
Old Aug 11, 2002 | 12:51 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Yeah, it's easy to get to. You should be able to leave the runners on. Once you pull the plenum off you'll see it sitting on the back crossover part of the fuel rail. One thing you will need though is a set of security Torx bits from your local parts store. They look just like normal bits, but have a whole in the center of them to acommidate the bump in the center of the screw. You can also pick up a new stock style FPR from the parts store for around $10 too.
Old Aug 11, 2002 | 07:08 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I actually managed to get my FPR off without the need for the security torx bits. I used the normal bits and gentle tapped them with a hammer to squash the bump down so that the bit would grip enough. It worked for me.
Robert
Old Aug 14, 2002 | 10:45 PM
@ZZKKER's Avatar
well it wasnt the regulator, next comes replacing the pump
thanks
anthony
Twin_Turbo
Mar 14, 2016 10:10 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
m00n420
Sep 11, 2015 02:39 PM
lakeffect2
Sep 7, 2015 03:52 PM
Strick1
Sep 4, 2015 07:11 AM
