Injector Problems
Old Aug 12, 2002 | 03:04 PM
TransAmTPI's Avatar
Injector Problems
Has anyone ever had an injector go bad. if so could you tell me the symptoms. my car is running very bad and there is no engine noise. just had it tuned up in the spring with new plugs, wires fuel filter, and a new coil. the car idles high, around 1000 in park, but the idle is very rough. there are no SES codes and at high RPM's it almost sounds it is popping. also around 2000 RPM the entire cars shakes quite violently. if it isnt in the spark then i guess it has to be a bad injector or connection. ive checked everything i can think of with no luck.
Old Aug 13, 2002 | 01:30 PM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Is your car kinda hard to start after it has been driven around? I have an injector leaking somewhere from what everyone says. The car basically floods out when it is trying to start. If i let it sit for a few days after everything is nice and dry it will start right up with like 1 turn of the motor.
Old Aug 13, 2002 | 02:30 PM
Engine: LS1 V8
bryan623
Mar 22, 2021 06:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
tmellott89
Aug 16, 2015 02:58 PM
