Gaskets???
Old Aug 14, 2002 | 12:44 PM
CamaroX84's Avatar
Gaskets???
Well, as soon as my heads arrive, the big project begins - installing a Stealth Ram intake, 195cc AFR heads, and a Comp camshaft. I have put a list together of all the stuff I will need to complete this task, but can someone please double check this to make sure I have everything.
-Intake gasket (Felpro 1205)
-Head gasket (Felpro 1010)
-Valve cover gasket (Felpro 1603)
-Thermostat gasket
-Valve covers/bolts (since my old ones are centerbolts)
-Ignition wire looms
-Fuel fittings for Stealth Ram
Also, what header gasket do you guys recommend. I would like a copper one but I do not have a part number. I have Hooker 1 5/8" headers if that makes a difference. Any help would be greatly appreciated. Thanks.
Old Aug 14, 2002 | 02:03 PM
rezinn's Avatar
You're going to also need some water pump gaskets, a timing set, timing chain would be a good idea, some sealer for the head bolts and the water pump bolts, black or orange permatex silicone for the front and back of the intake. I'm sure there's stuff I'm forgetting. As far as header gaskets go.. I've never blown mine and they are cheap felpros. Go with whatever you want, just make sure you torque down the bolts good. I really like arp header bolts.
Old Aug 14, 2002 | 05:14 PM
CamaroX84's Avatar
Thanks for the reply. I don't think I need a new timing chain set, since I just replaced it one year ago (about 5-6K miles).
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
