engine problems..leaking antifreeze
Old Aug 17, 2002 | 06:12 PM
pete86iroc's Avatar
well today, i first noticed that my brake bads went bare.., on the front..back are drum, but then..
i thought my car had overheated..well it did, sort of, but i popped the hood..and theres green antifreeze all over the damn motor.., but it wasnt weak..like a blown head gasket or anything, no white smoke..what could have caused this?..i thought this only happened when something blew
also there isnt a bolt right now, the water pump bracket..could this cause it to be loose and not work or somehting?
right now.the motor runs , fine..except for the normal probs it had b4 and the leaking coolant.., fan runs..but the motor overheats...
blah
Old Aug 18, 2002 | 03:02 AM
rezinn's Avatar
First of all you should clean off your engine and refill the radiator. Then run it around and pop the hood to see where it's leaking. If you're missing a bolt in your water pump that is very bad and you need to fix it asap. When does it overheat? Is it just because you're low on coolant?
Old Aug 18, 2002 | 09:06 AM
pete86iroc's Avatar
yeah..it overheated before cuz the fan didnt work..now it does..(it just started working one day?)..but it overheated yesterday cuz the coolant leaking..
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
