88 5.7 GTA Rough on cold start?
Old Aug 18, 2002 | 09:40 AM
jcsws6's Avatar
My 88 GTA runs a little rough on cold starts and has a little hesitation when you first push the gas. I just did tune up yesterday with new plugs, wires, cap, and rotar. I'm getting a service engine soon light when its cold (haven't had a chance to pull the code). But if I turn it off when it warms up and restart it the service engine soon light goes off and it purrs like a kitten, and runs like a champ. I'm baffled, any suggestions?
thanks
Old Aug 18, 2002 | 03:04 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
You need to check the code.
Mine does the same, but I don't get a code. At least you have something to go on. Check the code. Might just be a sensor gone bad.
Mark.
Old Aug 18, 2002 | 04:05 PM
jcsws6's Avatar
Just checked the codes, got a 12, and a 34. My book says for a 88 TPI this code would be low airflow MAF sensor. My question is my air filter is realy dirty (just ordered a power shot filter) could this be throwing the code? Correct me if anything is incorrect
Old Aug 18, 2002 | 04:45 PM
xformula79's Avatar
Could possibly be a problem with the cold start injector.
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
