I got some probs
Old Aug 18, 2002 | 03:00 PM
luver350conv's Avatar
I got some probs
My car always started in a turn of the key, Then I installed the msd coil and it started in a half a turn of the key. Now when i installed my battery to the trunk so i could put slp induction in my car turns and turns, then i stop and gotta do it again and about half the time it starts and if it dont turn over i just drain the battery. We ran the power wire to the starter but the other positive lead where the battery used to be i didnt know what to do with so i just taped it off. The old negative wire i ground to the shock mount. so i dont know if i did it wrong or i have a fuel problem. but now i noticed that when i put my blinker on the volts move up and down. Need help fast, I dont want to ask for a jump every where i go. HELP HELP
Old Aug 18, 2002 | 04:52 PM
xformula79's Avatar
A bit confused by your post, but I think the positive lead that you taped off may have been the alternator wire, which would explain the fluctuation in voltage while the car is running. The problem with you car not wanting to start is most likely an unrelated matter because if the battery is strong enough to turn the engine over it is strong enough to keep the car running... for at least a few minutes.
Old Aug 18, 2002 | 05:27 PM
I was kinda thinking that with that end taped off that the fuel pump wasent getting enough voltage to supply sufficent fuel. because even when it keeps turning over when someone jumps me it takes like 20 seconds of turn at least to start
Old Aug 18, 2002 | 07:14 PM
I ran a coder on it and i comes up a 42, which one of the things listed is the fuel cut off relay has probs, this could be the prob rite and if it is how do i fix this
Old Aug 19, 2002 | 10:37 AM
problem fixed, i unplugged the fuel pump relay and plugged it back in and also the coil now it fires rite up.
84z96L31vortec
Aug 20, 2017 12:16 AM
billybob6110
Sep 24, 2016 09:50 AM
customblackbird
Oct 1, 2015 04:30 PM
89 formula TPI
Sep 8, 2015 08:00 PM
z28addict8490
Sep 5, 2015 03:56 PM
